Enables or disables Online Certificate Status Protocol (OCSP) check for Transport Layer Security (TLS) connections to remote Syslog servers.
| syslog | Specifies configuring the remote Syslog target. |
| tls | Specifies configuring TLS. |
| ocsp | Specifies configuring OCSP for real-time certificate revocation status checking. |
| on | Enables OCSP (default). |
| off | Disables OCSP. |
By default, OCSP is enabled.
While you can disable OCSP, it is not recommended because no certificate revocation status check is performed.
The following example enables OCSP check for TLS connections to remote Syslog servers.
# configure syslog tls ocsp on
This command was first available in ExtremeXOS 30.7.
